AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   abs problem (https://www.audiforums.com/forum/b5-models-69/abs-problem-190287/)
aa-4 Dec 12, 2012 01:29 PM
abs problem
96 A4 2.8 v6 12v quattro
anyone have an idea why my abs activates at 2-7mph while not on the brake? i have no lights on but it engages wether im on the pedal or not.
thanks
MetalMan Dec 12, 2012 02:21 PM
Probably one of you ABS sensors is damaged or not pushed in far enough. If you have VAG-COM you can diagnose which sensor is causing this.
aa-4 Dec 12, 2012 02:39 PM
regretfully i dont have vag-com yet... ill check the sensors. this wouldnt be caused from the infamous abs module would it? i believe it throws a light when its the module. correct?
mtroxel Dec 12, 2012 03:05 PM
Yea its not a failure of the ABS module. You'd have two lights (brake and ABS) and your ABS would never engage.
aa-4 Dec 12, 2012 03:34 PM
Awesome! thats what i thought. thanks
