Acceleration Problem
Old May 13, 2009 | 09:17 PM
Bosno's Avatar
Default Acceleration Problem
I have been noticing a problem with acceleration. I used to be able to feel a little acceleration but now I go up to 5000 rpm without really feeling much of a pull. THe turbo might not be kicking in either. Other than the turbo, what else could be causing this.
I have 2001 a4 1.8t
Old May 13, 2009 | 10:01 PM
redline380's Avatar
Legal Moderator
is your cel on? even if its not get the car scanned for dtc's. you could posibily be in limp mode
Old May 13, 2009 | 10:20 PM
Bosno's Avatar
Only the airbag cel is on, but that's been on. I might go check it out though, if there could be dtc's without cel
Old May 13, 2009 | 10:49 PM
redline380's Avatar
Legal Moderator
def check that and if you were to install a boost gauge that would help greatly. then we could actually tell what your boost levels are
Old May 13, 2009 | 11:01 PM
Bosno's Avatar
So the scan would tell if I'm in limp mode? Cause that seems like its the problem, not getting much acceleration even though I can go fast.
Old May 14, 2009 | 12:33 AM
redline380's Avatar
Legal Moderator
no, it wont. it will show any dtc's that may cause limp mode
Old May 14, 2009 | 12:49 AM
ghost6303's Avatar
a boost gauge would tell you instantly if you were in limp mode or not.
Old May 14, 2009 | 02:20 AM
Bosno's Avatar
Hmm,it would but I dont think I should get it just to tell if I'm in limp mode. I guess ill get it scanned then go from there.
Also how would I know if its just the turbo, if its out
Old May 14, 2009 | 09:40 AM
McGovs2.7TB5's Avatar
tell tale signs of bad turbo are usually a "dentist drill" sound when accelerating or lots of white smoke coming out of the exhaust. You should def look into a boost gauge, they can really help in diagnosing problems and they're easy to install. Every turbo car should have one.
Old May 14, 2009 | 04:01 PM
Bosno's Avatar
Does turbo usually go out at a set amount of miles or is it random?
