acceleration problem II
Old May 14, 2009 | 04:33 PM
sakuraba's Avatar
Default acceleration problem II
Hiyas, Im running a 99.5, giac with the 710n and full exhaust and ive been have a reoccuring acceleration problem. For a while everything was fine and dandy until day when id try to give her gas the car would start to studder past 5-8psi. I put new plugs in and boom and the problem magically dissappear, but now it seems to have magically reappeared. Have a check engine light rocking too.
Thanks for help / suggestions
Old May 15, 2009 | 12:43 AM
gaberossi's Avatar
since you have a pre-face lift ecu you might not be able to find out some codes like you would with the 00 and up cars...i just had a huge ecu problem and i had stuttering worse than any i have ever seen so just in case your diagnostics comes up clear look further into it and try flashing it back to stock then back to giac...
Old May 15, 2009 | 01:16 PM
redline380's Avatar
Legal Moderator
definately get a scan. not to be mean but its kinda useless to tell us you got a mil on and not tell us which codes where retrieved. your pretty much leading us on. with that said, i would be willing to bet its a problem with the ignition. i would even go so far as to guess your code(s) that is retrieved will be p030x indicating a misfire on an random cylinder. with what you have given, my guess would be a coil pack, but you gotta supply the codes.
Old May 15, 2009 | 02:43 PM
ghost6303's Avatar
you have the information, why dont you go get it?
and pull a spark plug while your at it to make sure they arent somehow fouled already.
i.am.gustav
Apr 23, 2013 06:10 PM
superdude-
Sep 5, 2011 07:25 AM
roman_pushkin
Aug 21, 2010 05:45 PM
Bosno
May 18, 2009 10:51 PM
tonig
Mar 5, 2008 08:43 AM
