Adjustable fuel pressure regulator
Old Feb 14, 2008 | 01:13 AM
machetetooth's Avatar
Default Adjustable fuel pressure regulator
The previous owner of my car installed an adjustable fuel pressure regulator.
Why would he have done this?
How do I go about adjusting it correctly? I have an air/fuel ratio gauge, but that isn't much help.
Thanks in advance
Old Feb 14, 2008 | 01:19 AM
cincyTT's Avatar
I'm make believe
Default RE: Adjustable fuel pressure regulator
He may of had a differnt turbo set up or thought he ran lean at some point. You want to just have it set to 4bar (~60psi). Need to know what kind you have to help you set it if its not already there.
Old Feb 14, 2008 | 10:20 AM
kraylon's Avatar
i have a 034 motorsports adjustable fuel presure regulator and i have it because i noticed that one day the bowl that the regultor sits in was filling with fuel and 034 had a sale on the adjustable ones which made it 10 dollars more then the factory replacement one since my only opition was the dealer. what kind do you have does it have a name on it or a picture can help us help you
Old Feb 14, 2008 | 05:42 PM
It's an audi brand. Has the rings on it. The adjustments are made with an allen wrench.
Here's a close up of it.
Old Feb 14, 2008 | 11:37 PM
kraylon's Avatar
do you have a fuel pressure gauge under the hood too?
Old Feb 14, 2008 | 11:50 PM
not that I know of. Can it be done without one?
Old Feb 15, 2008 | 03:13 AM
kraylon's Avatar
not that i know of
Old Feb 15, 2008 | 11:45 AM
cincyTT's Avatar
I'm make believe
Put it this way, its like messing with boost w/o a boost gauge. Not something you want to do.
Old Feb 15, 2008 | 11:54 AM
techbod's Avatar
no gauge = no good, I would fit a standard one or have it tuned
Old Feb 15, 2008 | 02:21 PM
cincyTT's Avatar
I'm make believe
All he needs to do is get a gauge from ecs for like $30-40 and cut the fuel line and slide in the gauge. All he has to do is pull the fuel pump fuse and let the car run till its stalls out.
