Vacuum line routes
Old 07-12-2010, 03:23 PM
omj123's Avatar
Default Vacuum line routes
Thanks for the last help guys. As promised, more questions. This time I am trying to fix vac lines. When I pulled the front end off I discovered 3 small vac lines going nowhere. One from the turbo area and two more under the intake. There is a nipple at the front of the intake on top that looks to be the right size. Which hose goes there. I can find no other empties. The two under the intake come out a part (?) attached to the intake. One comes out towards the back and then does a u-turn and heads forward the other comes out the front of said part and also heads towards the front. All lines appear cracked and brittle so I will replace all. Again all help would be much appreciated.
Old 07-12-2010, 03:31 PM
TeeterTawter's Avatar
http://i26.photobucket.com/albums/c1...uumrouting.jpg
the diagram on the right is what the stock vacuum routing is like
riydan
09-30-2010 01:09 AM
cefurod
04-02-2009 08:45 PM
audi_n00b
08-07-2008 12:42 PM
headshok2002
06-04-2005 01:52 PM
jblum
02-20-2005 12:18 PM
Quick Reply: Vacuum line routes
