airbag light weirdness
Old May 4, 2012 | 03:50 AM
ou2mame's Avatar
Default airbag light weirdness
so my high beams weren't working, so i went into the fuse box and looked around found some fuses blown and replaced them. then i start my car and my airbag light is on. i check the fuses and **** and nothing blown. i drive, 2 minutes later it goes off. i park i get out i get back in i drive, its on again. i'm staring at it, and it turns off a few minutes later.
make any sense? i know it shouldn't be on, but it turns off randomly, every time.
Old May 4, 2012 | 08:25 AM
ImTheDevil's Avatar
You need to have the airbag module scanned to see which one is tripping the light. It's strange that it goes out though - every time I've seen anything to do with the airbag light, once it comes on, it requires an active reset with Vagcom (a store's scan tool won't help you - you need Vagcom to do this). Makes me wonder if you have a short somewhere that's just tripping the light. If you have no stored airbag faults, I'd start suspecting this.
Old May 12, 2012 | 12:48 PM
mboclassic's Avatar
I think it was the staring that did it! \-D
Was your car ever in an accident? I had a similar problem, but mine a tree jumped out at me, the bag was nice enough to become a tasty marshmellow in my face...so some stickiness, $$$ later, and a new airbag installed etc etc ... the airbag light is still on!
Dealer wants an arm and a leg for a new module. Does anyone recommend a module repair or heard of module rebuilds? If so where/who?
Old May 12, 2012 | 12:50 PM
mboclassic's Avatar
mboclassic's Avatar
Old May 12, 2012 | 12:51 PM
jonbonesjones's Avatar
Moderator
don't need a module repair
jeremy is right the airbag light can't go away unless its killed in vag com. i turned my car on with no airbags hooked up and got the light even after connecting them it didn't go away until it was reset via vag com.
OP id suspect a short tripping the light.
HolyokeAudi
Dec 17, 2014 09:13 AM
pologoped2
Jul 28, 2013 05:47 PM
v8_ranch
Aug 27, 2012 12:45 AM
Niclipse
Apr 11, 2011 05:29 AM
Dunzie182
Nov 30, 2006 07:10 PM
