All 4 windows will not roll up and sunroof will not move.
Hi I just have a question about the electronic windows on the A4 Quattro that I have. I recently had the battery disconnected and when I reconnected it and tried to roll up the windows nothing happened. I checked all the fuses on the driver side and the relay panel everything had power to them. I am really not sure what the problem is. I had also tried the switches on all the doors nothing worked. If anyone knows a fix please let me know.
Have not heard of that but when I disconnect the battery the windows work just not auto. So I would try the same thing that I do to get auto to work (if not already tried) - With the ignition on pull up and hold for a couple seconds... the switch (as if you are wanting the window to go up - close). Then try it. Only thing is this has nothing to do with the sunroof so it seems like it may not work. But worth a try.
Oops - did not see the date.. probably got it fixed.
Audinick81
04-30-2008 01:40 PM
