alots of problems:need help
Old Sep 7, 2009 | 05:15 PM
Patty J's Avatar
Member
Default alots of problems:need help
Year:1996
make:audi
Model:a4
Motor:2.8 v6
Trans: 5 speed fwd
Problems: started up today and when i drove it it was falling on its face really bad. still accellerated not as hard but it did. i do not know what this issue is at all never even owned an audi before the motor sounds a lil louder like an exhaust leak with cams but i dont have any cams this car is completely stock!
check engine light came on it randomly flashes rapidly and then stops and stays on solid doesnt go off. it has this whinng noise that i thought where brakes and it gets louder as i accellerate determined it was brakes or exhaust leak im really not sure where to go with this any info would help me out greatly!
was told it could be a coil pack or a 02 sensor but i have no idea please help thanks
call me im me anything i just need help and direction
Old Sep 7, 2009 | 05:23 PM
Andrew149's Avatar
get a scanner or have it scanned post up the codes and we can tell u
Old Sep 7, 2009 | 05:33 PM
Patty J's Avatar
Member
last tiem i had it scanned i had a cylinder 6 misfire
Old Sep 7, 2009 | 05:41 PM
Andrew149's Avatar
ok well than u will need to replace your coil pack u can buy from this site or get oem coil pack and it haft to be oem or it will misfire again the aftermarket sucks this website is great for oem parts http://www.ecstuning.com/Audi-B5_A4-...tion/ES252237/
ghost6303's Avatar
last time is not this time.
Old Sep 7, 2009 | 05:43 PM
Andrew149's Avatar
maby he hasnt fixed the issue?
Old Sep 7, 2009 | 08:46 PM
Patty J's Avatar
Member
correct i started with the plugs and that didnt really help the misfire issue. this car is completely stock down to the coil pack im probably the most active owner of this car its had....andrew how did u determine coil pack if u dont mind me asking?
Old Sep 7, 2009 | 09:14 PM
Andrew149's Avatar
well coil packs well make your car run rough the idle will go up and down like you have said and also the exhaust will change it's tone haha and u said it sounded like it has cam's
Old Sep 7, 2009 | 11:43 PM
pyropenguin's Avatar
don't just throw parts at it without confirming first... swap the coilpack from cyl 6 to one on the other bank, clear your codes, drive a while until it misfires again, and then scan the codes.
If the problem goes away on cyl 6 and pops up on the one you swapped it to, just replace that coil pack.
Old Sep 8, 2009 | 09:40 AM
bradtyler02's Avatar
Exactly what I was going to say, and exactly what I did (on my 1.8, but same idea) and yes, it confirmed a bad pack. Always look for a way to verify for free, or next to nothing, before you start throwing cash at it. Although, I've heard Audi always runs better after wadding up some cash and throwing it at the engine... (can't remember who said it in which thread, but still makes me laugh!)
