Amp Install......
Old Feb 8, 2008 | 07:19 PM
rhyab1's Avatar
Default Amp Install......
Has anybody found a good spot to run a fat power wire thru firewall to hook up an amp? I finally got a amp but cant locate anywhere to run cable,nothing is visible,my friend said something about removing some plastic under hood to access but I havent been able to spend any time f-ing with it and my installers havent worked on my model car....
Old Feb 8, 2008 | 09:30 PM
turbo kraut's Avatar
Tech Guru
Default RE: Amp Install......
run it into your ecu box, then through the grommet in the firewall
Old Feb 8, 2008 | 10:06 PM
FASTER's Avatar
Tech Slut
i ran 0-gauge wire through the gap inbetween the fender panel... just unbolt it and slip the wire through, then bolt it back up.
Old Feb 8, 2008 | 10:23 PM
pyropenguin's Avatar
ECU box
or
Hood Release cable grommet (remember to seal it up though)
Old Feb 9, 2008 | 12:06 AM
carcrzy24's Avatar
I found a small gromet just to the drivers side of the center console just punch a hole in it and put it back
Old Feb 10, 2008 | 02:18 PM
sdsteez's Avatar
ORIGINAL: pyropenguin
ECU box
or
hood release worked for me. seal that **** up real well after youre done tho (guerilla glue will last forever) or youll get tons of water in your cabin, like a river
Old Feb 10, 2008 | 03:06 PM
CAB509's Avatar
6th Gear
https://www.audiforums.com/m_318162/tm.htm
ask and ye shall receive
Old Feb 14, 2008 | 09:13 PM
sam.hollis's Avatar
I've done them a bunch of times a the stereo shop I work at and did mine last week ran 0 awg through the rubber gromet that the ac lines come through the passenger sidetons of room and its sealed from the rubber.
Grey2007
Feb 23, 2012 01:17 PM
kevinbednarek
Feb 22, 2012 06:19 PM
Brautty
Jan 21, 2012 12:38 AM
Dave666
Jul 12, 2005 08:47 AM
1996a4
Apr 4, 2005 04:09 PM
