Anyone running REVO software?
Old Dec 13, 2010 | 01:05 PM
chocalotstarfish's Avatar
Super Moderator
Originally Posted by Mike-2ptzero
Not going to find a huge amount of people running REVO on the B5 since they only offer tuning for the 2001 when it comes to the B5. Most of those are running the BT tune with the elim kit. Revo prices for the K03 tuning for a 2001 should be the same as their tunes for the B6. Pretty sure its only going to be a stage 1, the stage 1+ tunes for the B6's are a injector upgrade because they have a non fuel return system. The 2001 has a fuel return and FPR just like the rest of the B5's. This is why you dont see any tuners offering injector upgrade stage 1+ kits for the B5's.
Have you throught of maybe going with the Frankenturbo upgrade since it basically looks exactly the same as your K03? I am a Frankenturbo dealer now, it will give you about the same power or slightly more then a stage 3 but not nearly as much power as a stage 3+(GT28rs).
Since you are ndbw, your only options are going to be APR, GIAC or Uni. If your choices right now are just APR and REVO, you can only go APR since Revo doesn't offer tunes for the ndbw cars. They only tune the wide band cars.
Didn't know that REVO only did dbw... on their site it just says 1.8t... good to know! I wish I could upgrade the turbo but so much money and a whole nother level of racing then I could do Uni but they are only stage one to where with the apr I can go stage two and eek out a few extra hp!
Originally Posted by FasterA4ThanUrs
Mike wants you to cheat Don
lol I was like "I see what he's saying"
Time to make some more phone calls! I was meeting up with the shop owner so we could sit down see what mods I'm aloud and what I'm not and then pick the tune and stage from there! Super nice guy!
Old Dec 13, 2010 | 01:19 PM
Mike-2ptzero's Avatar
Its called bending the rules. lol
Plus he didn't state that he couldn't upgrade the turbo, he said he couldn't go Stage 3 wihich means he coudn't go with a turbo that makes it look like he has upgraded. What are the rules he has to stay within?
IIRC in autox to stay in a stock class you cant even do chip tuning or any power mods. Odd thing is if you do you end up running in a Modified class which means running against cars like my A4.
APR stage 2 is just K03 tuning for an intake and test pipe/HFC, do the rules allow for removing the stock cat and running a CAI?
Old Dec 13, 2010 | 02:15 PM
Super Moderator
I'm in DSP (D is the group-SP= Street Prepped)
And a simple answer to your question is yes...
Turbo changes I'm aloud/not aloud...
C. Induction allowances are as follows:
1. Carburetors, fuel injection, and intake manifolds are unrestricted,
subject to 15.10.D. Alternate throttle linkage and connections to
facilitate installation of allowed induction systems are permitted, but
may serve no other purpose. If an induction system item is allowed
to be removed and its original mounting bracket can be removed by
simply unbolting it, the bracket may be removed as well.
2. Except for standard parts as defined in these rules, the external use
while on course of liquids, ice, dry ice, refrigeration systems,
vaporized compressed gases, etc. to reduce the temperature of the
intake air charge is prohibited. Wrapping of intakes with liquidsoaked
fabric is not permitted.
3. As utilized only on engines originally equipped with forced induction,
induction charge heat exchangers (known as “intercoolers” or
“charge air coolers (CACs)”) are unrestricted in size and
configuration. Air-to-air CACs and radiators for air-to-liquid CACs
must be cooled only by the atmosphere, except for standard parts.
Body panels, fascias, or structural members may not be cut or
altered to facilitate CAC installation.
4. Turbochargers and/or superchargers (“forced induction”) may not be
added, changed, or modified (this does not allow ceramic coating of
turbochargers). On vehicles originally equipped with forced induction:
a) No hardware changes or alterations to turbocharger(s) or
supercharger(s), in size or number, are permitted. Turbochargers
or superchargers may be updated/backdated only in conjunction
with the accompanying complete engine unit.
b) No changes are allowed to waste gate(s) size, number, or
location. No changes are allowed to variable-geometry turbine
(VGT) hardware.
c) No changes are allowed to supercharger drive system pulleys.
Belt tensioners may be added/changed to reduce belt slip.
d) No changes are permitted to blow-off/pop-off valves.
e) Compressor bypass valves (CBVs) are considered part of the air
intake system and may be added, replaced, or updated/backdated
independently of the other components of a forced induction
system.
f) Boost regulation systems, either electronic or mechanical, and
electronic fuel cuts referencing boost pressure may be altered or
modified except as prohibited herein. Boost pressure changes
resulting from authorized changes are permitted.
Old Dec 13, 2010 | 02:37 PM
FASTER's Avatar
Tech Slut
Hmm, not sure they'd let me in that class.
Don, get a frankenturbo. They are so small that tech inspection would probably have no idea. You could claim the gains are from tuning/fueling. Unless they really know VAG's, they'll be none the wiser. I mean look how far a tune and diff injectors can get you on an Evo ya know.
Old Dec 13, 2010 | 02:51 PM
Super Moderator
You'd be in a Mod class cuz of the 2.0 >.< I can't afford a frakenturbo right now! I'm barley affording the software + supporting mods! I still need new wheels and tires too
Old Dec 13, 2010 | 04:14 PM
So by those rules you can only change to a turbo that was used on your engine stock and can change the fueling/tuning/boost levels.
Old Dec 13, 2010 | 05:07 PM
FASTER's Avatar
Tech Slut
I was kidding.
God, an RS Evo could kill in your class.
Old Dec 13, 2010 | 05:18 PM
  #18
Super Moderator
They would be in a different group.
Street Prepared Class D
Acura
Integra (1990-93)
Integra (+ Type R) (1994-01)
RSX (all)
Alfa Romeo
1600 Coupes & Spiders (all)
1750 & 2000 Coupes & Spiders (all)
GTV V6 (all)
Milano
Audi
A4 (1.8T, FWD & quattro) (1995-01)
A4 (1.8T, FWD & quattro) (2002-10)
Coupe & Quattro Coupe
BMW
325 & 328 (E30 chassis)
323, 325, & 328 (E36 chassis)
328 & 330 (E46 chassis, non-M3)
3 Series (16v, NOC)
Bavaria
Chevrolet, Pontiac, Buick, Oldsmobile, & Geo
Cobalt SS (n/a) (2005-07)
Cobalt SS Supercharged (2005-07)
Cobalt SS Turbo (2008-10)
HHR SS Turbo
J Body (4-cyl Turbo, Quad 4 DOHC, & V6)
L Body (Quad 4 & V6)
N Body (4-cyl Turbo, Quad 4, & V6)
Spectrum Turbo (1985-89)
Storm GSi (1985-89)
X Body (V6)
Chrysler, Plymouth, & Dodge
Acclaim (V6 & Turbo)
Charger GLH-S
Conquest & Starion (non-turbo)
Daytona Turbo
Daytona (V6)
GLH-S & GLH Turbo
Laser Turbo (NOC) & K-car Turbo
Shadow (4-cyl Turbo & V6)
Shelby Charger Turbo
Spirit (4-cyl Turbo & V6)
SRT-4
Sundance Turbo
Dodge & Mitsubishi
Colt Turbo & Mirage Turbo (1984-88)
Colt Turbo & Mirage Turbo (1989-92)
Eagle
Summit Turbo (16v) (1989-90)
Fiat & Bertone
X1/9
Ford & Mercury
Capri (4-cyl & 6-cyl) (1971-77)
Capri (1991-95)
Contour SVT
Cougar (1999-2002)
Focus SVT
Fusion & Milan (6-cyl) (2006-10)
Probe (Turbo & V6)
Honda
Civic Si (1999-2000)
Civic Si (2002-05)
Civic Si (2006-10)
Del Sol (DOHC)
Prelude 4WS
Prelude (1983-2001) (NOC)
Hyundai
Tiburon
Isuzu
I-Mark LS (16v & Turbo, FWD) (1985-89)
I-Mark RS (16v & Turbo, FWD)
Impulse RS Turbo (AWD) (1990-93)
Impulse Turbo & RS (RWD) (1983-89)
Impulse XS (16v non-turbo) (1990-93)
Impulse (16v & Turbo)
Stylus XS & RS (16v) (1990-93)
Lexus
IS300
Maserati
BiTurbo
Mazda
323 GT & GTX (AWD)
6 (6-cyl)
Mazdaspeed 3
Mazdaspeed Protege
MX-6 (Turbo & V6)
Spec Miata (See 15.0 for preparation allowance requirements)
Mercedes
190 (1984-93) (all)
C230
Merkur
XR4Ti
MINI
Cooper S (+ JCW & JCW GP)
Mitsubishi
Cordia Turbo
Eclipse (2000-10)
Galant (all)
Tredia Turbo
Nissan & Datsun
200SX SE-R
200SX Turbo
200SX (V6)
240SX
Maxima
Pulsar (16v)
Pulsar NX Turbo
Sentra (2.0L) (1995-99)
Sentra (2.0L) (2000-01)
Pontiac & Toyota
Corolla XRS (2005-06), Matrix XRS (2003-06), & Vibe GT (2003-06)
Matrix & Vibe (AWD) (2003-08)
Porsche
914 (4-cyl)
924 (Audi engine)
Renault
Fuego Turbo
R5 Turbo
Saab
99, 99 EMS, & 99 Turbo
900 & 900 Turbo (1979-93)
900 & 900 Turbo (1994-98)
Saturn
Ion (all) & NOC
Subaru
Impreza 2.5
Legacy & Outback (6-cyl, all) (1998-2004)
Legacy & Outback (6-cyl, all) (2005-10)
Toyota
Camry V6
Celica (2000-05)
Celica All-Trac (all)
Corolla FX16
Supra (1982-86)
Volkswagen
Corrado (all)
Golf & Jetta (VR6)
Golf, Jetta, & New Beetle (1.8T, Mk4 chassis) (1999-2005)
New Beetle Turbo
Passat VR6
R32
Volvo
240 Series Turbo (all)
C30 (2006-09)
6-cyl (n/a) & 4-cyl (mechanically forced-induction) 2WD sedans under
3.0L not otherwise classified.
(See Section 15.1.C for update/backdate limitations.)
Old Dec 13, 2010 | 06:31 PM
  #19
yeah there is no way an evo would be in the same class as a chipped K03 A4. lol
lisek99
Aug 6, 2009 10:05 PM
nighta46289
Jan 26, 2008 01:34 PM
Mya4T
Jan 1, 2008 11:53 PM
dafowler88
Dec 13, 2007 12:42 PM
Rodm21
Mar 6, 2006 11:45 AM
