ATTACK OF THE VAG COM
Old Mar 4, 2008 | 10:55 PM
machetetooth's Avatar
Default ATTACK OF THE VAG COM
So I vagged my car and got these codes:
P0300 Random/Multiple Cylinder Misfire Detected
P0301 cyl. 1 misfire
P0302 cyl. 2 misfire
P0303 cyl. 3 misfire
P0304 cyl. 4 misfire
P1602 Power Supply (B+) Terminal 30 Low Voltage
P0238 Turbocharger Boost Sensor (A) Circ High Input
P1544 Throttle Actuation Potentiometer Signal too High
P1172 Throttle Actuation Potentiometer Sign.2 Signal too Low
P0113 Intake Air Temp.Circ High Input
P0118 Engine Coolant Temp.Circ High Input
P1579 Idle Speed Contr.Throttle Pos. Adaptation not started
P1426 Tank Vent.Valve Open
[hr]
Anyone know what's up here?
I'm guessing my TB is bad/dirty, and I need to replace the ECT sensor. I'm not sure about the intake air temp. code. Is the intake air temp sensor part of the MAF? No clue about the high turbo boost sensor reading either.
My o2 sensors are probably bad too because they're reading 0.0%.
help me! please! thanks!
Old Mar 4, 2008 | 11:27 PM
qUaTtRoA4's Avatar
Default RE: ATTACK OF THE VAG COM
how long did it take for all of those codes to accumulate...that looks like a couple weeks worth of work...lol
I would clear all of your codes and see what comes back....do you have a CEL?
just clear 'em and take care of whatever comes back in the next couple days....how's the car running?
are you runnin a ko3 or a ko4 file?
gl!
Old Mar 4, 2008 | 11:50 PM
ORIGINAL: qUaTtRoA4
gl!
The car isn't driveable. It barely idles. If I clear the codes, I can't see what comes back because I can't drive the car. The codes are all fairly new actually, I reset the codes less than 50 miles ago.
Im running a k03 file.
Old Mar 4, 2008 | 11:57 PM
qUaTtRoA4's Avatar
wow, well it looks like you have a good idea of where to start
definately clean your maf
replace 02 sensors
replace ECT
the boost code may have been from a mad spike...lol...you could be in limp mode
besides that have you switched over to BKR7E spark plugs gapped to .28?
you definately need to figure out your missfires
start with plugs, if all cylinders are missfirring it could simply be your ICM
gl!
hope you get this **** sorted out [&:]
Old Mar 5, 2008 | 12:02 AM
ORIGINAL: qUaTtRoA4
replace 02 sensors
replace ECT
gl!
I hope I get it sorted out too. I have no money in the bank, so repairs would go on the credit card.
Things I have already done: Replaced plugs with bkr7e's with .028 gap, checked coil packs, cleaned MAF, replaced vac tubes (some not all), adjusted fuel pressure.
I definately did have mad spikes when misfiring, so that's probably the high boost code.
I'm a 2000, so I don't have an ICM.
Old Mar 5, 2008 | 12:22 AM
cincyTT's Avatar
I'm make believe
either you have a bunch of bad sensors or the ecu doesnt like you. Its claims your iat sensor, n75, coolent temp sensor, and a few other things are bad. Have you tried to reset the ecu yet?
Old Mar 5, 2008 | 12:28 AM
ORIGINAL: cincyTT
Yeah I've reset it a few times, still misfires, and the codes come back.
I forgot to post one of the codes..
18010 P1602 Power Supply (B+) Terminal 30 Low Voltage
Old Mar 5, 2008 | 12:29 AM
cincyTT's Avatar
I'm make believe
I dont know what to tell you. Auditech79 would know more i would think
Old Mar 5, 2008 | 12:35 AM
auditech79's Avatar
IF all those codes keep coming back i would be looking at the engine managment fuse, that controls all of those functions. I had a 3.0L do that exact same thing to me after i repaired it from fire damage and it was a blown fuse.
Old Mar 5, 2008 | 12:36 AM
cincyTT's Avatar
I'm make believe
See he aswered the ? and it WAS your ecu hates you...LOL!!!
