Audi A4 B5 Brights Headlight not working
Old May 14, 2016 | 05:28 AM
Wardes1984's Avatar
Default Audi A4 B5 Brights Headlight not working
Hi,
Have a problem, can somebody please assist, the dims and foglights are working fine but when I switch on the brights they don't come on. If you push the leaver towards you the brights come on but when you push it away from you they don't work. Can someone please tell me what could possibly be the problem and how I can fix it?
Thanks, Wardes
Old May 14, 2016 | 09:32 AM
A4TurboGuy's Avatar
Almost certainly the switch (lever).
Old May 14, 2016 | 10:52 AM
Wardes1984's Avatar
Default Audi A4 B5 Brights Headlights not working
Thank you. Can I fix it myself or do I need to replace?
Old May 15, 2016 | 10:50 AM
A4TurboGuy's Avatar
I'm sure it can be fixed, but I would just replace it with one from another car (unless you can find a new one cheap).
Old May 15, 2016 | 11:23 AM
george1546's Avatar
Yep +1 on the switch
Had the same exact issue. High beams will only turn on when flashing so pull towards you, they don't work if you pull away from you to keep keep them on. It def the switch.
Old May 17, 2016 | 08:36 PM
ImTheDevil's Avatar
You can DIY the repair (there's a procedure in the DIY forum on how to do it, and I wrote an additional one on how to fix your switch or rebuild it as well). You will have to remove and reinstall the airbag so be sure you're comfortable doing that yourself.
Old May 17, 2016 | 08:38 PM
ImTheDevil's Avatar
Wardes1984, where do you live? Please go into your user control panel and fill out the location info as well as create a signature with your car's relevant info. It'll save a lot of time and hassle when you ask questions and if people near you see where you live, you may get offers of help as well.
uscgjoe79
Oct 3, 2012 10:56 AM
Pappa Phil
Jul 21, 2008 10:01 PM
chuckhawk
Jan 19, 2008 05:58 PM
billdoor13
Sep 14, 2007 02:06 PM
vwwife
Jun 8, 2007 04:29 PM
