AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   Audi squeak (https://www.audiforums.com/forum/b5-models-69/audi-squeak-188641/)
boldenz Oct 25, 2012 11:49 AM
Audi squeak
My dad and i Just Bought a 1999 audi a4 avant quattro and when we push down on the back end it makes a squeakign noise, my dad put some spray on the back area of the car and the squeak went away until it rained, I was wondering what might be causing the squeak, my dad thinks its the controll arms but its only the back area that makes the squeak, so Please coment if u might know what might be makign the car squeak
Sheasta Oct 25, 2012 11:57 AM
Control arms? Strut? Strut mount? I think it could be any of these things. Mine just started doing it too. Im not sure if its the 12 inch subwoofer in my trunk or thats coincidental. It started happening shortly after i got the sub.
cnigro1279 Oct 25, 2012 02:06 PM
Rear, Upper, Inner
I have the same problem but know it is the rear-upper, inners that are doing it. When I did my rear wheel bearing, I noticed the rubber had completely seperated from the ring of the bushing and makes a hell of an annoying squeak. FCP has each bushing for around $17. I believe they have to pressed in/out. I used some spray silicone for awhile and it helps temporarily, but eventually they start to squeak again.
AudiDeficitDisorder Oct 25, 2012 06:52 PM
Depending on where you live and how much salt they use on the roads, they springs could be so rusty that they have broke and are rubbing on the strut. My A4 has lived in Upstate NY most of its life and had a horrible squeaking when going over large bumps.
mtroxel Oct 27, 2012 08:48 AM
It's one of the bushings back there. I have it right now, I even have the bushing...I'll change it some day this winter. Mine is in the lower arm, and you have to take out the E brake cable to get it out. But the busing gets old and separates, then you have rubber rubbing on rubber.
