AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   Auto window up/down on remote - Seen this? (https://www.audiforums.com/forum/b5-models-69/auto-window-up-down-remote-seen-105789/)
guy4graphics Jun 23, 2008 10:44 AM
I was browsing ECStuning.com this morning and noticed this:
http://www.adamsbiz.com/assets/ecs.jpg
I know most B5s have the auto all open or close feature built-in. But it only works when you put the key in the door, adding that functionality to the key-fob would be tight. I already checked with ECS and they don't carry anything like this for Audis. Does anyone know who might sell this?
jiggleo Jun 23, 2008 11:49 AM
RE: Auto window up/down on remote - Seen this?
you can do that with vag com. just enter the code I will put the link in later when I re-find it. you use your factory fob too.
https://www.audiforums.com/archive/t...-677324-1.html
sdsteez Jun 25, 2008 02:33 AM
got it done w vagcom, ITS THE 5HIT!!!!!
ImTheDevil Jun 28, 2008 01:07 PM
Yep it's a nice feature to add. I love having it, although I need to extend my remote antenna wire so I have more range to it. Between not having done that, and having a battery that I think is weak, I have to be within a few feet of the car for it to work most of the time. Hiwords can use his from 25 feet or more (saw it at my house) after extending his antenna, and I definitely am going to do the same thing.
nitro_rider2001 Jun 29, 2008 12:29 AM
whats the easiest way to extend the antenna?
hollisterrobsta Jun 29, 2008 01:33 AM
Just move the receiver, I believe its located under the passenger seats, so just remove the bottomseat and place it wherever you feel you will get the best reception.
ImTheDevil Jun 29, 2008 10:24 AM
The antenna coil may be under the rear seat (just pull up on it to remove it) or it may be down under the rear bumper, in the side frame rail. Just splice more wire onto it and wrap the wire around in the car. If it's under the rear seat, add several feet of wire and run it up the C-pillar and across the top of the back window, for example.
