Automatic Shift Knob
Old Feb 6, 2010 | 03:20 PM
Chewster's Avatar
Default Automatic Shift ****
How do you remove??? I have tried everything and searching and nothing??
01 A4 Quattro 1.8T
Old Feb 8, 2010 | 02:59 PM
Chewster's Avatar
b u m p
Old Feb 8, 2010 | 04:20 PM
Tourbo24's Avatar
i know that this is for audi q7 but you might as well try it http://forums.audiworld.com/showthread.php?t=2755803 good luck
Old Feb 8, 2010 | 04:25 PM
Tourbo24's Avatar
Old Oct 5, 2016 | 05:00 PM
06B7757's Avatar
Default I got it off... but how do I get it back on
I basically have it off but when I put it back on even with the zip tie thebutton goes in
Old Oct 5, 2016 | 05:45 PM
Mark C's Avatar
OFF:
shifter to gear 3 position, slide the lower chrome sleeve at the bottom of the **** down the shifter shaft, pull the shifter release button (what your thumb rest on) on the side out so there is about a 3mm gap showing between the bottom of the relase button and the ****. Pull straight up.
On;
Shifter in "N" position. Pull the shifter release button out again so there is about a 3mm gap between the bottom of the button and the side of the ****., put the **** on the shifter lever with the release button facing the dash then twist the **** so the shifter release button faces the driver, the **** should engage in a vertical groove on the shifter lever. Push the **** on the rest of the way until it engages with the ring groove on the selector lever. Push the release button back into the ****, and pull up the lower chrome ring until it engages on the bottom of the ****.
brrman
Jan 27, 2008 10:57 AM
azkevk
May 24, 2007 06:55 PM
FIUPike83
Apr 21, 2007 03:10 PM
budnfrida
Jul 7, 2006 07:52 PM
FezA4
Nov 7, 2005 02:19 PM
