automatic worth boosting?
Old Feb 18, 2008 | 10:26 PM
qUaTtRoA4's Avatar
Default RE: automatic worth boosting?
I would go with a GIAC chip $450 first (you will need to get a diverter valve at the same time)
forge/bailey DV- $150(alot of the time when you go to a local "tuner", they will give you a deal if you buy the chip and dv at the same time)
FMIC- $320 (custom godspeed set-up, some DIY involved)
Custom exhaust- $350 (2.5" exhaust piping, running to a magnaflow muffler, with a nice set of tips)
LaBree HFC/DP/TP- $100-250 (depends on emmisions in your state (if you have to smog you need a cat))
thats a pretty good start-up list....you should look into a tip chip (altlhough I am not sure if one is available for a '97)
And if you plan on making bigger power, the road that most atomatics take is LEVEL TEN
you can search on here and research more before making any decisions
NOTE: If this car is new to you , have it checked out, it is an 11 year old car...this is when the control arms go, motor mounts, tranny mounts, cv boots, oil cooler...and the list goes on and on...somewhere between 90-120K a lot of the parts I listed go out....along with gaskets and seals....
before performing a single mod, make sure that all of you maintenance is taken care of
here is another good site that you should take a look at audidiy.com
there are also many free mods available for our cars, just take a look in our DIY section....I remeber reading somewhere that you can convert a regular auto to a tiptronic...sounded kinda cool
alright, well, I hope something up there made some sense
gl!
Old Feb 19, 2008 | 07:03 PM
mr.cAp's Avatar
ORIGINAL: qUaTtRoA4
if your on a budget you could,
$100 FMIC DIY
$90 ebay Test Pipe
$125 Speed Tunning Chip (which you will not need the FMIC)
$40 Audi TT DV
That will give you a good start, and when you get the money upgarde either part.
Old Feb 19, 2008 | 07:10 PM
Leifer's Avatar
mr. cap, the piping alone costs more than $100, not to mention cores themselves are like $90
I got a custom-assembled piping kit (2.25" hotside to 2.5") which included 8 pipes, a 28x7x2.5" core, 16 t-clamps, and 8 hose / couplers for $189 -- not bad at all.
Old Feb 19, 2008 | 07:18 PM
osterthetoaster's Avatar
sweet thanks a lot guys
Old Feb 19, 2008 | 07:24 PM
Leifer's Avatar
Oster, let's put it this way:
Is it worth upgrading an automatic honda? No.
Is it worth upgrading an automatic Audi? Yes. Tiptronics are steezin', and there's several guys on AZ and a couple on here with tips that would blow M3s out of the water.
Old Feb 19, 2008 | 08:18 PM
mr.cAp's Avatar
ORIGINAL: Leifer
https://www.audiforums.com/m_382466/tm.htm
so i was off by $50
Old Feb 19, 2008 | 08:22 PM
Leifer's Avatar
Sorry, I didn't mean to sound like an ******* -- I'm just saying that with the notion that he wants to lay down some power at the wheels, and he'll need a much better setup.
Old Feb 19, 2008 | 08:28 PM
  #18
cincyTT's Avatar
I'm make believe
ANd you guys think 7-9 connections and a $90 ic is the right way to go?
Little tip, every connection you make causes more turbulance in the pipes and effects the flow. If you want better than stock, its fine. If you want it done right, you need to have it done right. You should be able to do it with 2 or 3 pipes. Thats 4-5 connections tops.
Old Feb 19, 2008 | 08:34 PM
  #19
alright guys thanks once again haha, i really aprecaite all the help you guys are offering
Old Feb 19, 2008 | 08:38 PM
  #20
Leifer's Avatar
Cincy, I'm expecting some of my pipes not to be used. You can do it with just a 45 degree bend and a 90 degree bend per side, right?
