automatic worth boosting?
Old Feb 19, 2008 | 08:40 PM
  #21
osterthetoaster's Avatar
Default RE: automatic worth boosting?
and how much does a tiptronic cost to get and get installed
Old Feb 19, 2008 | 08:41 PM
  #22
mr.cAp's Avatar
i never said i would choose that setup for myself i was mearly pointing out that if hewas on a budget it can be done, not trying to sound like an *** either.
Old Feb 19, 2008 | 09:08 PM
  #23
cincyTT's Avatar
I'm make believe
^ I never said you would. Just making a point of decent vs well done.
ORIGINAL: Leifer
Cincy, I'm expecting some of my pipes not to be used. You can do it with just a 45 degree bend and a 90 degree bend per side, right?
Think thats right. Plus the straits
Old Feb 19, 2008 | 09:10 PM
  #24
Leifer's Avatar
Yup. Hopefully it works out with that. Besides, with the extra pipes, I can finally make that bong I've always wanted...
Old Feb 19, 2008 | 09:12 PM
  #25
cincyTT's Avatar
I'm make believe
I guess.
DOnt forget a map sensor bung if you have a 2000+ everyone. Make sure you get the ones with the 2 fittings for the use of a large or small map sensor
Old Feb 19, 2008 | 09:13 PM
  #26
Leifer's Avatar
Uh oh. What?? My A4 is 2000 and I ordered no such thing.
Old Feb 19, 2008 | 09:16 PM
  #27
cincyTT's Avatar
I'm make believe
here you go chief http://www.20squared.com/catalog/pro...roducts_id=200
Old Feb 19, 2008 | 09:21 PM
  #28
mr.cAp's Avatar
Removed because i was wrong,
  #29
chaos92287's Avatar
ORIGINAL: Leifer
driver side can be done with two 90* bends, passenger side is 90 and a 45. so thats 2 pipes on each side. my recommendation is you weld the two pipes on each side together, that way you only have 1 pipe on each side
Old Feb 19, 2008 | 09:28 PM
  #30
Leifer's Avatar
Cincy, steel or aluminum?
Brian, I'm going to couple them instead of welding. I couldn't weld to save my life!
