b5 a4 transmission problem
Old May 21, 2013 | 10:20 PM
Audidonz's Avatar
Default b5 a4 transmission problem
i have a white 1997 audi a4 2.8l v6 quattro. i paid next to nothing for it and it has the following; remus full exhaust, coni fully adjustable suspension (slammed pretty good), tint etc. i can tell that someone has messed with the gearbox from the cabin. the plastic is cracked towards the carpet. I wanna say that someone installed a short throw. it is not the stock ****. It usually only happens from first to second but occasionally 2nd to 3rd. it seems like it slams into gear. even when starting from a stop in first when i move into first gear i feel a slight jerk.... i dont believe this is normal. there is about an inch of vertical up and down give on the shifter itself. and it has some horizontal movement when in gear. im not sure if the problem lies above the transmission or within it. if anyone has had the same issue advice is welcome. much appreciated
Old May 21, 2013 | 10:42 PM
Pbcrazy's Avatar
I don't really know what your saying but I'm assuming its a manual. Could be a lightweight flywheel and you just don't know how to drive it correctly yet, mine was really jerky in every gear except 4th and 5th until I got the hang of my lightweight
Old May 22, 2013 | 03:38 PM
Audidonz's Avatar
but should there be that much play in the shift **** itself?
Old May 22, 2013 | 03:49 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Yes. I have over an inch of side to side play in my shifter. The downward movement you feel is the push down reverse.
I have an ebay SS kit installed which shortens the throw but doesn't do anything for the slop. Check out the shifter stabilizer kits from JHM if you want to tighten it up.
mason13
Aug 24, 2013 03:43 PM
unnaturallyaspirated
Jun 20, 2013 08:14 PM
miminan
Nov 7, 2010 09:57 AM
wildgene789
Jun 29, 2008 07:27 AM
