back to leaking
Old Apr 28, 2008 | 02:34 PM
mudpuppu_94's Avatar
Default back to leaking
Ok. I had a similar post a while ago. Looked at all the others about leaks in the floor. When it rains i get a leak in the REAR drivers side floor. Last time i was thinking that it was the sun roof so i blew out the lines. Well i got deployed so i never found out if i fixed it or not. Right before i deployed for the second time as i was putting my car in a storage i noticed water there again. My question is..is what else could be causing the leak in the Rear passenger floor and only there?
Old Apr 28, 2008 | 03:16 PM
jibberific's Avatar
Default RE: back to leaking
I have the same problem and i really am wondering how to fix it, because the water just sits there and makes my interior all stagnant smelling until it eventually evaporates
Old Apr 28, 2008 | 04:13 PM
chaos92287's Avatar
did you check the sunroof drain plug? its right next to the ecu box in that back corner underneath the hood
Old Apr 28, 2008 | 07:04 PM
jibberific's Avatar
ok i went and looked under the drivers side of the hood around the ecu... and all i'm seeing is the grommet and hole that the hood release cable goes through
Old Apr 29, 2008 | 07:57 AM
No i didnt. The leak isn't in the front of the car. Its in the back. And i have already checked the sunroof drains a couple times. Any other ideas?
Old Apr 29, 2008 | 11:44 AM
chaos92287's Avatar
jibberific- thats the sunroof drain plug. pour some soapy water on it and see if its leaking through
mudpuppu- when the drain plug i was talking about leaks, a pool of water forms behind the drivers seat. i had this problem previously. if thats not it, then i dont know
Old Apr 29, 2008 | 11:55 AM
yea. i realized what you were saying after i posted. ill try putting soapy water on it and we will see when i get home in 2 months. im deployed again. if it doesnt wokr this time i guess i will be going to the stealership. thanks
Old Apr 29, 2008 | 09:01 PM
01afour's Avatar
crap i have this same thing. im gunna check the drains like you said. i was really hoping i didnt have a hole in the floor. im kinda happy if this is all thats wrong.....and how do i fix it?
Old Apr 29, 2008 | 09:32 PM
jibberific's Avatar
Hmm well when i saw that rubber grommet/plug thing i noticed it was unseated, like it was completely popped out of the hole... Maybe that's what was letting the water in? That would make sense, i'm gonna go outside right now and fix that
Old Apr 29, 2008 | 09:47 PM
01afour's Avatar
ahh lucky, its too dark for me to fix it right now but im doin it tommrow if thats all i gotta do. this actually makes me really happy cause now i know its not a hole in the floor somewhere.
