Bad axle?
Old Jan 19, 2012 | 09:12 PM
MetalMan's Avatar
Originally Posted by ecpfenninger
Alright thanks I will take a look, also I noticed what looked like snapped metal above the front right cv joint when I was replacing, I looked and I believe it is some sort of shield, is that correct? I can take pictures of the control arms and tie rods as well as the snapped shield if that would help at all. Thanks for the help!
There is normally a debris shield mounted to the upright, just compare the shield you think is damaged to the other side of the car. Keep in mind though that this shield could have been damaged in several different ways; one of mine was bent a bit when a new wheel bearing was pressed in.
Originally Posted by CCA4
Jack up the corner in question. Grab the wheel at 12 and 6 and wiggle it. Then again at 3 and 9. It shouldn't move hardly at all. If you're getting a lot of movement, something is definitely broken.
But if it doesn't wiggle that doesn't necessarily mean everything is okay...
Old Jan 19, 2012 | 09:26 PM
CCA4's Avatar
True, but it's a start, no?
Old Jan 19, 2012 | 09:51 PM
MetalMan's Avatar
I suppose, and if there is wiggle from worn control arm bushings then now would be a good time to replace the control arms anyways.
Old Jan 19, 2012 | 09:56 PM
02quattrokev's Avatar
You can't really have a bad "axle" with these kinds of cars. The axle is really just a stick with two CV joints attached to it. The only way it can go "bad" is by snapping, and if it did that you'd damn sure know it. If you replaced the damaged CV joint(s) from when you hit the curb you should be good from that perspective.
Have you had an alignment since you hit the curb? If you hit a curb hard enough to break a CV joint I guarantee you broke/bent other suspension parts. Control arms, wheel bearings, sway bar links, etc.
Forgive me if this sounds harsh, but if you're a young driver and this is your first winter, I'd be more inclined to think you haven't quite mastered driving on ice yet before I'd assume there's something wrong with the car. If you're fishtailing when you drive over something slippery that means you're being too liberal with the gas. Quattro is an awesome thing, but it doesn't make you invincible.
Snaping an axle isn't the only thing that can go bad with an axle. The clicking noise in a turn is another indication of a bad axle.
Old Jan 20, 2012 | 09:28 AM
CCA4's Avatar
No, clicking while turning is an indication of a bad CV joint. Which is exactly what I said in post #2. An axle is just an axle.
Old Oct 1, 2012 | 06:27 PM
Kaiser's Avatar
I get that clicking noise when turning at times. It's getting progressively worse. How much labor hours to replace one side CV joint assuming the job is done in a shop?
Rolling Blackout
Dec 21, 2011 07:02 PM
ampower14
May 15, 2011 07:03 PM
millenia
Aug 28, 2008 11:58 PM
sljone
Dec 8, 2006 08:08 PM
bajamoon
Feb 26, 2006 01:34 AM
