badgeless grill
Old Feb 18, 2009 | 10:52 PM
rlubbers's Avatar
Default badgeless grill
I just bought a badgeless grill from ecstuning.com. It says you need to move your hood latch. Is there a writeup or anyone that knows a good way to do this?
Old Feb 18, 2009 | 10:59 PM
kriptonik's Avatar
Open up your hood and check out the back part of the grille.
There should be couple of pins/clips that are holding the grille in place. Basically take a screw driver or use your own strength to unclip/unhook those little plastics.
Old Feb 18, 2009 | 11:02 PM
aledelic42's Avatar
There are just no instructions that came with the grille? What grille is it?
Old Feb 19, 2009 | 03:08 PM
rlubbers's Avatar
part number ES#9596 on ecstuning.com it says i have to modify the hood release to make it work
Old Feb 19, 2009 | 03:55 PM
kriptonik's Avatar
I thought you were talking about the Kamei badge-less but you have the FK badge-less grille.
It's similar to this:
Anyway, I have no idea how to install this particular one but like mentioned, there should be an instruction that came with the grille.
Maybe someone with experience with the FK can fill you in on this.
Old Feb 20, 2009 | 08:18 AM
TommyGunns's Avatar
The first aftermarket grill I had on my car was from FK, and you have to basically bend the latch so its pointing down. When you pop the hood, you still can reach it by putting your fingers under the lower edge of the hood.
joshuo
Feb 8, 2009 01:27 PM
Will_02_A4
Nov 23, 2008 02:39 PM
aramkim
Feb 15, 2008 04:03 PM
2kaudi
Oct 31, 2007 06:30 PM
blake00
Jul 8, 2006 08:17 PM
