Boost gauge!
Hey AF, I need to get myself a boost gauge soon and I want your imput. I'm leaning towards a vent mount because I despise column mounts. Where can I get a vent mount fairly cheap. AWE's are like $250 and that seemed somewhat steep. I don't mind if it doesn't work as a vent anymore or if I need to paint. Any other mounting locations to look into?
Also, any suggestions on a turbo timer? :cool: |
i cut out and dremelled a spot in one of my vents so it fit right in... all i did was buy the boost gauge!!
I'm hesitant to do that because I don't want to fuck it up. A nasty warped vent is not what I need.
Originally Posted by A4speed
(Post 1081815)
I dremeled mine out using sandpaper to fine tune the fit as well... Not that hard to do, just takes patience and taking a little bit off at a time until it fits snuggly.
1 Attachment(s)
+1 more for using a dremel
Thats how I did mine. It takes a little bit of patience and a steady hand. Start from the middle of the vent and trace out the gauge on the two center cross pieces, cut away until you can trace onto the next set of cross memebers etc. |
2 Attachment(s)
yea i used a dremil when i did my vent mount.. i now have a podi column mount. love it.
Old vent setup. Attachment 45113 new Podi Setup Attachment 45114 |
Since everyone is posting there's... Here's mine.
Sorry it's in the dark however... CLICK TO ENLARGE! http://thumb9.webshots.net/t/52/752/...9jLaeiI_th.jpg |
I have 2 used Autometer boost gauges I no longer use if you need one cheap. One is silver face and the other is white face.
