Boost gauge?
Old May 10, 2010 | 07:31 PM
lolo22's Avatar
Default Boost gauge?
Quick easy question, When installing the boost gauge do I tap into the line going from the dv to the intake manifold. If not which one is it.
Old May 10, 2010 | 07:39 PM
aledelic42's Avatar
you can or you can tap into the line on the opposite side of the manifold, close to the firewall. which is easier
Old May 10, 2010 | 07:45 PM
lolo22's Avatar
were does it run to as in point a to point b, Im a new audi owner so I dont know much about these cars or boosted cars. Is it the line running from the manifold to the fpr.
Old May 10, 2010 | 08:24 PM
lolo22's Avatar
the line closest to the fire wall
Old May 10, 2010 | 08:56 PM
tware4021's Avatar
i tapped into the line on the top of the pic...i just put a T fitting in and connected it there and runs perfectly fine for me.
Old May 10, 2010 | 09:38 PM
turbo kraut's Avatar
Tech Guru
yeah, use the frp line
Old May 10, 2010 | 11:46 PM
joenelson7687's Avatar
What is the correct VAC reading supposed to be? I've heard of 20 but some say anything up to 15...
Old May 11, 2010 | 06:32 PM
bump*
Old May 11, 2010 | 06:53 PM
lolo22's Avatar
Just finished installing it today, Im getting 20 for the vac reading and between 5 to 8 pounds of boost. This sound right for not being chipped.
Old May 11, 2010 | 07:22 PM
It's just that I'm at 15 vac and I can't find out for the life of me if I have a leak anywhere...anyone else? Thank you, btw
