Boost Gauge Pod Options
Old May 8, 2014 | 05:46 PM
adam044's Avatar
Default Boost Gauge Pod Options
I'm looking for either a pillar pod or maybe even a pod that would sit flush on top of the dash. I got a universal pillar pod from autozone but it doesn't fit right so I was wondering if there is an Audi specific one.
Got tired of it in the vent. Doesn't look clean to me.
Old May 9, 2014 | 01:37 PM
A4TurboGuy's Avatar
They all suck (I searched everywhere). You'll have to fab your own if you want it to look good.
Here's mine:
Old May 9, 2014 | 02:18 PM
adam044's Avatar
Here's mine:
That came out perfect. I just ordered a steering column mount. They seem to look ok in the pictures I've seen. I just want something out of the way.
Old May 9, 2014 | 02:25 PM
MetalMan's Avatar
Steering column pods will partially block visibility of your instrument cluster - particularly where the LCD screen is.
Old May 9, 2014 | 02:34 PM
adam044's Avatar
I noticed that in the pictures I saw. It's not like it tells me anything important anyways. I find it depressing watching my miles until empty constantly going down anyways. All the important information shows up in the top box.
Old May 9, 2014 | 04:48 PM
Mad Cow's Avatar
I'm toying with the idea of getting a numeric digital boost gauge, taking the circuit board out of the circular casing (possibly remote mount the LCD if circuit board's too big) and fabbing up a steering column mount. It should only stick out an inch max so shouldn't block anything.
Old May 9, 2014 | 04:50 PM
adam044's Avatar
This sounds cool. Would be interesting to see how it comes out. Totally keep up updated if you do it
Old May 9, 2014 | 04:53 PM
Mad Cow's Avatar
Will do. That's only the first step of my plan, in the end I want to make a multifunction display to show things like oil pressure, boost, oil temp maybe, depends on what kind of sensors I can get a hold of. It's amazing what you can do with a $15 Arduino, $10 LCD and a couple of sensors.
Old May 9, 2014 | 04:54 PM
adam044's Avatar
Sounds like you've have this idea for a while now. You should give it a go!
Old May 9, 2014 | 07:46 PM
Pbcrazy's Avatar
If I remember correctly Metalman took out his analog clock and put his oil pressure gauge there, you could probably do something similar if you have the time/expertise
