AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   Boost Gauge Pod Options (https://www.audiforums.com/forum/b5-models-69/boost-gauge-pod-options-207753/)
adam044 May 8, 2014 05:46 PM
I'm looking for either a pillar pod or maybe even a pod that would sit flush on top of the dash. I got a universal pillar pod from autozone but it doesn't fit right so I was wondering if there is an Audi specific one.
Got tired of it in the vent. Doesn't look clean to me.
A4TurboGuy May 9, 2014 01:37 PM
2 Attachment(s)
They all suck (I searched everywhere). You'll have to fab your own if you want it to look good.
Here's mine:
Attachment 24827
Attachment 24828
adam044 May 9, 2014 02:18 PM
Here's mine:
http://i620.photobucket.com/albums/t...psed574b36.jpg
http://i620.photobucket.com/albums/t...ps7851132a.jpg
That came out perfect. I just ordered a steering column mount. They seem to look ok in the pictures I've seen. I just want something out of the way.
MetalMan May 9, 2014 02:25 PM
Steering column pods will partially block visibility of your instrument cluster - particularly where the LCD screen is.
adam044 May 9, 2014 02:34 PM
I noticed that in the pictures I saw. It's not like it tells me anything important anyways. I find it depressing watching my miles until empty constantly going down anyways. All the important information shows up in the top box.
Mad Cow May 9, 2014 04:48 PM
I'm toying with the idea of getting a numeric digital boost gauge, taking the circuit board out of the circular casing (possibly remote mount the LCD if circuit board's too big) and fabbing up a steering column mount. It should only stick out an inch max so shouldn't block anything.
adam044 May 9, 2014 04:50 PM
This sounds cool. Would be interesting to see how it comes out. Totally keep up updated if you do it
Mad Cow May 9, 2014 04:53 PM
Will do. That's only the first step of my plan, in the end I want to make a multifunction display to show things like oil pressure, boost, oil temp maybe, depends on what kind of sensors I can get a hold of. It's amazing what you can do with a $15 Arduino, $10 LCD and a couple of sensors.
adam044 May 9, 2014 04:54 PM
Sounds like you've have this idea for a while now. You should give it a go!
Pbcrazy May 9, 2014 07:46 PM
If I remember correctly Metalman took out his analog clock and put his oil pressure gauge there, you could probably do something similar if you have the time/expertise
