AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   Boost problems (https://www.audiforums.com/forum/b5-models-69/boost-problems-117272/)
brimhall99 Oct 31, 2008 01:51 AM
Boost problems
So when my car is cooler and the temperature outside isnt to hot my car boosts fine and there are no problems, but when my car is hotter and hot outside the car doesnt boost worth shit. I have hooked it up to a regular check engine light reader and there are no codes. (waiting for vag-com to be shipped) any ideas? have changed the MAF, oxygen sensor 2, spark plugs and all coil packs. Also does anybody know how many wires are running into the back of the MAF plug?
TeeterTawter Oct 31, 2008 04:34 PM
boost leak, when its cold everything shrinks, as it heats up, things expand.
you have an 00, it looks like 1 wire was pulled out from the maf right?
A4speed Oct 31, 2008 05:51 PM
do you have a boost/vacuum gauge installed? readings?
brimhall99 Nov 1, 2008 02:30 AM
in 4th and 5th gear i have full boost all the time, when shifting into 1st 2nd and 3rd there is a really loud crackling noise, and there is no boost. waiting for my vag-com to be shipped to see what codes pull up, also I heard that if there is a crackling noise while in boost means that it is getting to much fuel, true?
brimhall99 Nov 1, 2008 02:31 AM
Ya I rewired the MAF and there was only 4 just making sure that was normal
ryanylva Nov 1, 2008 12:33 PM
Has the TB been changed? Just wondering cuz the waterpump and thermostat are usually done at the same time. If your temp reading is not straight up at halfway then it will tell the ECU to lean out.
brimhall99 Nov 1, 2008 06:53 PM
the temperature gauge is only over half way when i get done driving and the car is off for about 15 minutes then i go to start it at its barely past half way, it goes down after about 30 seconds, the timing belt was changed 10,000 miles ago
onepoint8tee Nov 1, 2008 07:27 PM
Do you have a boost gauge?
brimhall99 Nov 1, 2008 11:26 PM
No I need to get one, is a wire clip broken by my fog lights, thinking it is the barometer sensor, what does that do?
brimhall99 Nov 2, 2008 03:15 AM
anyone?
