Brake Fluid Flush With ESP
Old Aug 7, 2009 | 08:25 PM
cantdrive55's Avatar
Question Brake Fluid Flush With ESP
I'm planning on flushing my brakes tomorrow and have heard conflicting reports of needing vagcom when having esp. Any idea for sure if I need it, and if so what's the procedure? Another thing is I usually go rr, lr, rf, lf but with it being an Audi there's always a special trick so I just wanted to make sure its that way.
Old Aug 8, 2009 | 01:14 AM
Tweaked's Avatar
Just manually flush them. Manually flushing them with a pressure bleeder will push the fluid through the ABS lines. Unless you've experienced issues with the ABS pump or valve block or have replaced ABS hydraulic parts, it's not really necessary to use a VAGcom.
But if you'd like to do it, the ESP/ABS pump must be activated using basic settings.
Some more info:
http://vwforum.vwforum.ro/index.php?...post&id=128400
Old Aug 8, 2009 | 01:18 AM
hiwords's Avatar
+1 to what tweaked said
Old Aug 8, 2009 | 03:10 AM
Yea I picked up a Motive Power bleeder through ECS and will give it a shot tomorrow. So my caliper order is correct?
Old Aug 8, 2009 | 10:57 AM
ObnoxiousDrunk's Avatar
you are correct. I'm pretty sure you start from the farthest point from the reservoir and work your way closer to it, so Right Rear, Left Rear, Right Front, Left Front is correct. I think the rule of thumb is if the reservoir is on the left you start right rear and if the reservoir is on the right you start right rear
Old Aug 8, 2009 | 12:50 PM
Midniteoyl's Avatar
Soo... right rear?
Old Aug 8, 2009 | 01:01 PM
ghost6303's Avatar
#1- passengers side rear
#2- drivers side rear
#3- passengers side front
#4- drivers side front
#5- clutch
i just did a brake flush today as well. i guess its that time of the year. that is the order i used.
ECS Tuning
Oct 30, 2014 03:54 PM
AR15Texan
Jun 10, 2009 12:24 PM
rgall
Jun 19, 2008 08:04 PM
