Brake light out, replaced bulb, now tail light is out. Help?
And I cannot get it to work at all!
Note: When taking out the bulb harness(if that is what it is called) I broke the tail light/brake light bulb. I replaced it with an 1157 bulb and now the brake light works, but my tail light will not turn on. I switch the bulb from the passenger side, which does work for both lights, and it too works for the brake, but not the tail light. I have triple checked that I placed the bulb in correctly. I have made sure there was nothing inside the harness to screw up a connection. I have made sure all the wires from the wiring harness to the bulb harness are secure/not corroded or cut. No clue what to do or what to test now to see what the culprit is. Could it be a fuse? I thought if the fuse went out the brake light would not work either. Help? |
Are you sure you're not confusing one of these bulbs with the rear fog light?
Is it a dual filament bulb or single? Have you checked for 12V? If it was a fuse, both rear tails would be out. Just throwing out some info to think about. |
I think you got a single filament bulb!
