broken bolt...?
Old Dec 3, 2014 | 12:42 PM
zero-o-matic's Avatar
Default broken bolt...?
Hey so I started to take off my front bumper so that I can remove the engine to do the clutch. The passenger side bolt came out, but the drivers side bolt cracked. so i only have half and the bumper will not come off. any ideas where to go with this?
Old Dec 4, 2014 | 07:55 AM
A4TurboGuy's Avatar
How far was the bolt un-threaded before it broke? How much thread is left in there?
Old Dec 5, 2014 | 09:41 AM
id say about 60% of the thread is still in the receiving part of the bumper
Old Dec 6, 2014 | 07:54 AM
A4TurboGuy's Avatar
If it's only one side, you can swing the bumper out some, lube it up really well (just the threaded area) and try drilling a hole big enough to use an extractor on it......or Vice grips.
Do you have any pics?
Old Dec 6, 2014 | 09:06 AM
mtroxel's Avatar
This sucks Zero. I don't know if you can an extractor and vice grips in there.
Here's one idea. It's just threaded into an aluminum plate that's riveted to the top side of the bumper frame. Can you put a long punch up there and beat the broken bolt straight up? The idea is to break that aluminum plate so that maybe the bolt will drop out of the threads. Its worth a shot.
Old Dec 7, 2014 | 07:43 AM
A4TurboGuy's Avatar
Another idea I had was if you can get a high powered drill in there (18+V), then you might be able to grip onto the bold (like a drill bit) and unscrew it by "drilling" it out.
My 18V Dewalt has a "Hammer" setting - almost like an air ratchet (for masonry work). That might do it.
GL
Old Dec 7, 2014 | 09:50 AM
ill be at my shop this week and can take pictures. and try to drill it out.
Old Dec 7, 2014 | 09:52 AM
mtroxel's Avatar
It's a tough one zero. As your last resort, you might have to cut a hole in the top of the plastic cover so you can break up that plate the bolt is threaded into.
Old Dec 8, 2014 | 09:29 AM
A4TurboGuy's Avatar
A pic would be nice.
I'd love to help you get this done "easily", because having to blow out the threads would suck.
Old Jan 30, 2015 | 11:46 AM
sorry for the delayed response. I finally got the bumper off. I created my own tool using the torx and a wrench to pull off the mount to the frame. The biggest problem is you can't get the socket and ratchet in there(no space). so if you take the torx and put a wrench and muscle behind it you can loses the mount to frame bolts. (I skipped the step for removing the bumper from the mount) Then when the mount was off the frame, I cut out the bolt. Then drilled and re-tapped. Ended up working great! now to swap suspension parts!
Matthew Shaw
May 17, 2012 05:55 PM
240sxsr
Feb 16, 2010 08:20 PM
Norman71055
Apr 27, 2009 05:51 PM
c1welder
Apr 21, 2009 09:11 PM
lyndonwil
Oct 29, 2007 07:47 AM
