broken tube in engine
Old Oct 4, 2008 | 10:26 PM
viper_04649's Avatar
Default broken tube in engine
what is this tube? It is filled with gunk. It is really frail and just snapped when i touched it. This is a '99.5 2.8Q 5V
Old Oct 4, 2008 | 11:52 PM
cincyTT's Avatar
I'm make believe
ITs the breather system for the engine. That gunk is oil bypass. You need to clean it out and either fix it or replace it.
Old Oct 5, 2008 | 02:07 AM
hiwords's Avatar
either tape it back together with this black tape they sell at the parts store that is heat resistant. or if you don't care, duct tape it until you have enough money to buy a new one. daym thing is expensive. another thing you can do is rig up your own hoses
Old Oct 5, 2008 | 02:32 AM
cincyTT's Avatar
I'm make believe
easiest is to just cut off the cracked parts and use a larger diam hose over that section, but the best is just replace it all so you can get rid of the clog also
Old Oct 5, 2008 | 11:16 AM
mott6904's Avatar
i used to get a big piece of heat shrink tubing to put on it. I works great and looks clean.
Old Oct 5, 2008 | 11:20 AM
I think i am going to just shrink tube it for now. My concern is that since the tube is clogged, probably the tube that it connects to (top right of pic) is also clogged, along with other things. What is the function of this in my engine?
Old Oct 5, 2008 | 12:26 PM
Jc61990's Avatar
5v... dont u mean 30v?
Old Oct 5, 2008 | 01:30 PM
either or. 5v per cylinder. just being humble to the people with only 24v.
Old Oct 5, 2008 | 01:50 PM
cincyTT's Avatar
I'm make believe
i have already answered this, post #2 in fact!!
Old Oct 5, 2008 | 03:49 PM
shady927's Avatar
mine broke when I was changing my spark plug wires I just replaced it with neoprene tubing and that has worked out pretty good
