buying advice on high mileage b5 2.8
Good day
I once had a 1999 a4 1.8t and it was a fun time. Not sure exactly sure why but I find myself very interested in a 1999 A4 quattro 2.8 with 225K miles for $1700, which appears overpriced. The car is a single owner car with all the service records. Good: -Interior is in good shape except for ripped leather on drivers seat -sunroof actually works -Drives very smoothly -Owner changed oil every 5K without fail -Front axles changed @ 218K -Timing belt, water pump, drive belt all changed at 213K in Apr 17 -Front brakes at 189K -timing belt, crankshaft and cam seals, water pump and cam sensor at 182K in July 2011 -Clutch and right cat done at 171K in Oct 2010 -Coolant reservoir and cam plug at 160K in Apr 09 -Valve cover gaskets, spark plug seals, timing chain gaskets in 2008 at 150K -ABS control unit at 122K - I can add more but not sure what else is key Bad: -Car has nasty smell of burning oil at first and then clears up. Owner says he checks oil first of every month and usually adds 1/2-3/4 qt. I'm guessing valve cover gaskets -Car AC works intermittently and best on highways. I'm guessing auxiliary fan -Don't see fluid changes except for brake fluid at 140K and rear diff at 85K -Last repair shop slip said clutch was worn but seemed to shift fine to me. My questions overall are: 1. Am I walking into a money pit of high mileage maintenace especially with the suspected issues? Am i better off saving my $$. I'm able to do basic car maintenance, not sure about advanced work. 2. Is there anything else I should be looking for with the car? Thanks |
My 1996 2.8 Quattro has 267xxx and rips |
My advice is to not buy another Audi...and if it's your first Audi it will be the biggest car buying mistake you have made thus far.......any model.
