Can anyone help Please
audi a4 1997 the indicators,wipers and a/c fan not working hazard lights are working tho i have checked the fuses but are ok has anyone come across this problem. many thanks
it sounds like bcm with bad connections , try checking the ground and power in the connector see if this helps
dont suppose you could tell me where to find the bnc modual many thanks
dont suppose you could tell me where to find the bcm module many thanks
it should be next to the latch for releasing the hood, i may be wrong
ive found the bcm's no probs thanks but i cannot work out which module is the one thats causing the problem, i dont suppose you have any idea, Many thanks Again for your time
