AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   Car is doing weird things. Help me fix it. (https://www.audiforums.com/forum/b5-models-69/car-doing-weird-things-help-me-fix-138049/)
generik777 Sep 2, 2009 08:34 PM
Here's the problem. The car runs good most of the time. But it will randomly start to shake and misfire really bad like it's going to die for about 1-2 minutes with the CEL flashing and then return to normal and a solid CEL which eventually goes out. Also sometimes i can feel it start to shudder lightly for a split second or 2 like it wants to go into this misfiring spasm, but then snaps out of it before it can.
The few time I noticed it seems like its normally between 1000-2000 RPM's when this happens. Also I noticed it seem more likely to happen when I drive somewhere, put the car in park and let it sit for awhile, and then drive away. 3 times it happened within just a couple minutes of me doing this. Other times I can drive for several hours or days without it happening.
I brought the car to the dealer which scanned it and came up with some random misfire codes for a couple cylinders. They had already replaced the injectors on a couple of the cylinders a few months back so they ruled that out. So they pressure tested all cylinders and they came back good. Plugs and wires are new. They replaced the coil packs and coolant temp sensor, they were unable to reproduce the problem after doing this so they called me and I picked it up. I've had the car for 4 days now and it just today did it again for the first time.
I also noticed that if I get the car to about 40 then let the revs drop down to just barley above 1000, then just lightly give the gas a quick kick it will shudder slightly. Any Ideas? They seemed pretty stumped at the dealer mostly because how randomly the so called misfire spasm happened. Thanx. Car is a 30v 2.8 BTW.
Andrew149 Sep 2, 2009 08:42 PM
im stumped too...
revolyawbus Sep 2, 2009 08:46 PM
weird... mine was shuttering and would drop below 1000 when i was just sitting there and it was the water pump?
Andrew149 Sep 2, 2009 08:51 PM
i mean his timing could be off on his car??? that would cause some nasty miss fires do u know what type of coil packs there are like what i think r is the latest?
revolyawbus Sep 2, 2009 08:55 PM
i know a buddy that bought new wires and because they wernt labeled he wired them wrong.... luckily i was there before he started it up
Andrew149 Sep 2, 2009 09:00 PM
maby they didnt gap his spark plugs 0.32
revolyawbus Sep 2, 2009 09:15 PM
mine didnt need to be
Mr. Phil Sep 2, 2009 09:17 PM
what year did they start doing coil packs? cuz i have plugs and wires still
ImTheDevil Sep 2, 2009 09:36 PM
The coil packs are under the center engine cover. They drive the plugs through spark wires. You have them - this car just doesn't have coil-on-plug ignition with the packs sitting over each plug.
revolyawbus Sep 2, 2009 09:39 PM
i was going to say they never got rid of wires
