CEL and misfires
Old Oct 3, 2009 | 12:49 PM
collins's Avatar
Default CEL and misfires
OK found out it was a leak and this is where the leak is..
what is this piece? it doesnt seem there is a way to make it stay connected
Old Oct 3, 2009 | 12:57 PM
CRAZYHAWK's Avatar
16684/P0300/000768
From Ross-Tech Wiki
Jump to: navigation, search
Contents [hide]
1 16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
1.1 Possible Causes
1.2 Possible Solutions
1.3 Special Notes
Possible Causes
Air Intake System leaking
Fuel Supply faulty
Injector(s) faulty
Ignition Cable(s) and/or Spark Plug(s) faulty
Ignition Coil(s) faulty
Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
Camshaft Position Sensor (G40) faulty
Possible Solutions
Check Misfire Recognition
Check Air Intake System
Check Fuel Supply
Check Injector(s) and Injector Sealing
Check Ignition Cable(s) and Spark Plug(s)
Check Ignition Coil(s)
Check Exhaust Gas Recirculation (EGR) Valve (N18)
Check Camshaft Position Sensor (G40)
Special Notes
This DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cylinder.
Old Oct 3, 2009 | 12:58 PM
auditech79's Avatar
You need to get your hands on a better scan tool, i doubt your are misfiring on all four cylinders because your engine probably wouldn't run. If its just random misfires on all four cylindes it could be caused by a huge vacuum leak, which you could probably find easilly just by popping the hood with it running. You should hear air being sucked into the engine somewhere.
If you a bad coil pack, you could swap the pack to a different cylinder and see if the misfire moved. Since you didn't post the fault codes i couldn't tell you that.
Old Oct 3, 2009 | 01:13 PM
collins's Avatar
yeah i just went out and checked it was a leak, im uploading a picture now becuase it looks like a piece needs to be replaced where the leak is but im not sure exactly what it is.
Old Oct 3, 2009 | 01:28 PM
collins's Avatar
updated with a pic
Old Oct 3, 2009 | 03:22 PM
collins's Avatar
http://www.ecstuning.com/Audi-B5_A4-...oses/ES261411/
could this be what i'm looking for, this is the closest looking thing i could find on ecs
Old Oct 3, 2009 | 04:27 PM
bradtyler02's Avatar
Old Oct 3, 2009 | 04:43 PM
collins's Avatar
thanks, guess piece is the suction pump then
Old Oct 3, 2009 | 04:45 PM
I don't remember the details now, just that the poor guy almost crashed because his brakes failed. Didn't want the same thing to happen to you...
Old Oct 3, 2009 | 05:55 PM
collins's Avatar
yeah mine were doing the same thing on the way to autozone. had to use the ebrake to stop and keep the rpms up so it didnt stall the whole way there. atleast it was an easy fix, now just waiting on ecs to get me my new piece.
srosati
Jul 26, 2014 09:29 AM
Mott Power
Sep 6, 2009 03:31 PM
RaFa
Feb 5, 2008 05:56 PM
khj677turbo
Aug 24, 2007 12:06 PM
Fall0ut
Nov 9, 2005 11:40 PM
