CEL on - read sticky, changed ICM and coil packs, what else?
Old Oct 6, 2009 | 12:47 PM
fritz's Avatar
Default CEL on - read sticky, changed ICM and coil packs, what else?
originally, i had the probelm of misfiring as per the code reader on cylinder 1, changed the coil pack and also changed the ICM.
it fixed the problem, it was driving fine for a couple days.
i go on vacation for 5 days, didnt start the car since and now i am getting a misfire on cylinder 3.
i have since changed the coil pack on cylinder 3 and still am getting the same problem (CEL blinking and rough idle)
what else?
i also noticed that the engine temp seems to be off but am not sure if that is related.
something else worth noting, i was on the road and i ran over some flying road debris (unavoidable) went through the underside of my car and may have hit something that would trigger this?!
your thoughts?
Old Oct 6, 2009 | 01:41 PM
dragonrage's Avatar
coolant temp sensor can cause lots of problems
Old Oct 6, 2009 | 01:44 PM
ghost6303's Avatar
the road debris could have hit the lower intake hose that connects the turbo to the cross pipe on the bottom of the radiator. check to see there isnt any leaks around there. if it isnt a leak i would be looking at the MAF sensor for unexplained random misfires. if its the original MAF i would replace it now anyways.
drft1
Jul 5, 2010 12:19 PM
audiquattroa4
May 6, 2010 04:40 PM
kraylon
Jul 29, 2009 12:19 AM
tsd02
Apr 6, 2009 08:32 AM
grpayne
May 1, 2005 03:10 PM
