circuit breaker....
Old Aug 9, 2010 | 07:03 PM
holdin16's Avatar
Member
Default circuit breaker....
anyone have a picture and or diagram of where the powerwindow circuit breaker is?? windows arent working need to get them fixed!! ive tried everything
Old Aug 9, 2010 | 07:16 PM
NickBroderick's Avatar
My passenger window wouldn't go down when I used the drivers side control, I took the door panel off and jimmied the connector, worked fine. Dropped my car off at Meineke the other day, now it won't go down again. I didn't care because I knew I could fix it. Well, I took the door panel off again, disconnected then reconnected the plug, twice, and now it still doesn't work.
Long story short, I may need the same info as you.
Old Aug 9, 2010 | 07:31 PM
holdin16's Avatar
Member
its ridiculous. i have checked everything, fuses wires under the dash. in the door. under the hood its driving me nuts
Old Aug 9, 2010 | 07:42 PM
I have a bentley manual that I always forget about, maybe I can check that in a bit for ya.
Old Aug 9, 2010 | 07:46 PM
holdin16's Avatar
Member
mamn anything would be greatly greatly appreciated. i dont think the windows are getting any power at all. they dont work from any switch none of the windows work. the switches dont even light up at night when the lights are on. ive checked everything that i can think of and i dont have a clue
Old Aug 9, 2010 | 09:28 PM
CCA4's Avatar
got volt meter? Could just be the switch gone bad, definitely not uncommon
Old Aug 9, 2010 | 09:29 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
My left rear window switch wouldn't roll up for awhile. Now it does .
But yeah, its probably the switch.
Old Aug 9, 2010 | 11:11 PM
holdin16's Avatar
Member
none of the switcches work on any other doors
Old Aug 10, 2010 | 06:55 AM
CCA4's Avatar
IIRC, power to the other three doors (the two back doors for sure) is routed through the driver's door. Make sure there's power to the driver's door
Old Aug 10, 2010 | 08:59 AM
holdin16's Avatar
Member
There is no power to the driver door switch that's the problem. I've checked all the wares and everything. What else can I look for?
