clear corners
The ideal mod is to replace the entire headlight assembly with a 1 piece e-code... of course thats expensive... Clear corners is a good simple mod that makes an impact to the look of the car.
Matrix Racing. Look under Lighting -> Euro Corners
Best price I've seen - Same ones I have. Here's hint get some silver spray paint and lightly (not a full solid coat) spray the orange bulbs. That way you wont see them til they actually light up.
<edited><editID>brrman</editID><editDate>38055.4483680556</editDate></edited>
wow this kid dont f**k around......or you could do what I did just get colored bulbs(not blue or red) most cops wont mess with you for having colored turn signals in the front cuz depending what state you live in the laws are kinda non specific about the fronts....</P>
I got purple signals and side markers and headlights/foglights.....BTW corey get aftermarket side markers those amber ones are ugly dont you think</P>
heh heh - you can get clear bulbs that light up amber also - they cost more but not too much. I think they are made by Phillips.
Slim - I'm sure once he replaces the corners he will all about replacing the sidemarkers... heh heh
The corners are very very simple to install...
open your hood - look directly down behind the corner on the inside of the engine bay - you will see a small plastic tab with a loop at the end, folded over the corner's tab. Hook that loop with a screwdiver and loosen the tab... pull corner out.
twist the bulb holder so that it releases from the corner and you're gravy, babeeee
