Coilover installation question
I installed H&R coilovers on my 2001 1.8T quattro over the weekend, but there seems to be something not quite right when I drive the car. Normal roads and minor bumps are no problem, but when I hit some big bumps the car makes some clunking noises. Do I need to cut/modify the stock bump stops? It feels like the car has no travel distance when it hits big bumps. Any advice would be much appreciated. Thanks.
The car isn't that low...yet. I was waiting for the car to settle then planning on making adjustments. How much did you have to cut your bumpstops?
Yes.. you always need to adjust and tighten suspension components (especially the bushings) with the full weight of the car on them. If you dont, you 'pre-load' them and cause binding, which in turn causes rough riding and noise. I usually lower the car onto jackstands under the hub.
If you adjust the ride hieght later, you need to loosen and retighten the control arms, again, to prevent binding.
