Coolant flange location
Old Aug 2, 2012 | 12:15 AM
shango11's Avatar
Default Coolant flange location
I'm trying to change the coolant flange in my 01 audi a4 1.8 turbo. The problem is that I've been following a DIY but I'm not able to locate the coolant flange, can someone post a clear picture so I can get an idea of were it is, I know it supposed to be behind the motor but I cant seem to find it.
Old Aug 2, 2012 | 08:58 AM
CCA4's Avatar
Welcome to AF!
The flange you're looking for is on the back of the cylinder head, below and to the driver's side of the combi valve. I posted an exploded view of an AWM head for you. The combi valve can be seen more easily than the coolant flange, it's shiny and round. Find that (#12 in the diagram), then look down and to the right, if you're standing in front of the car. You'll see the coolant temperature sensor plugged into a black flange, that's the coolant flange. It's #14 in the diagram. Hope that helps!
Old Aug 3, 2012 | 03:08 PM
shango11's Avatar
Thanks for the help! I finally found it and one of the o-ring was completely missing, hopefully changing that will stop the leaking for good.
vasja222
Nov 26, 2010 09:25 PM
ckappler
Nov 23, 2010 08:56 AM
seabassx
Apr 20, 2009 02:31 PM
chaos92287
Nov 7, 2007 01:46 AM
less_of_me
May 2, 2007 03:29 AM
