Crank position sensor
Old Oct 25, 2011 | 01:48 PM
DOC_DEPALMA's Avatar
Default Crank position sensor
I'm trying to remove and test mine. I have the front end torn off again (lol I'm a ****** pro at that now btw) and the harness off it, as well as the ground behind the crank pulley.
Question, how is it removed? I see one large nut at the base of it and I believe there's an allen (correct me if im wrong) key on the back of the sensor, which (if any) combination of these enables the sensor to be removed?
Also if anyone has any advice as far as how to test the sensor with the good ol multimeter, I would appreciate that as well!
AMERICA!!!
Old Oct 26, 2011 | 12:48 AM
Somebody's gotta know, My searches told me this is a common enough repair - just not how to get the little guy out..
Old Oct 26, 2011 | 02:28 AM
crazyquik22023's Avatar
If it is anything like the 1.8 crankshaft sensor (which I'm pretty sure it is since I believe the 4 & 6 cylinder engines both use the same sensor), it is held on by just one 5mm hex head bolt. It will take a little bit of turning and pulling to get it off b/c there is an o-ring around it.
Old Oct 26, 2011 | 12:08 PM
Alright thanks man I'll check that out and keep this posted for the other Noobs like myself
Old Oct 28, 2011 | 06:16 PM
mikekey's Avatar
Ahh, the good old crank sensor. I need to replace mine soon too.
RoyH
Dec 1, 2012 11:44 AM
Panzer6682
Oct 14, 2011 06:50 PM
jonzo
May 12, 2009 07:59 PM
idice
Feb 14, 2005 11:22 PM
idice
Jan 31, 2005 10:02 PM
