Crazy lights
I just installed some new after market head lights light. The connection for the signal light doesnt conect with the OEM connector. I started it and the lights wont come on. My ignigtion switch was recalled but havent had it replaced yet. Could this be the problem, all fuses good and if I hit the signal it makes a real fast clicking noise, much faster than it should. Any help would be appreciated. Thanks in advance.
Forrest |
So your signals aren't connected? When the system notices a lack of current, say a burnt out bulb or in your case a disconnected one, the bulbs will flash faster than normal. This notifies you that a bulb is burn out somewhere. All the bulbs, will flash faster than normal.
Do the lights come on when you hold the high beams back, as if you were to flash someone? |
What aftermarket head lights did you buy?
