Custom Intake With Pics
Old Jun 3, 2008 | 01:35 AM
BLK_A4's Avatar
Default Custom Intake With Pics
Ya so make up my own intake with a heat sheild and i thought i was just let you guys see. Sorry for bad cell phone pics.
Old Jun 3, 2008 | 02:12 AM
Tweaked's Avatar
Default RE: Custom Intake With Pics
Mm. Under hood air. Watch your MAF and fuel trims with a scan tool. You'd be suprised how much restricted, hot air you're sucking even with a heat shield.
Old Jun 3, 2008 | 02:20 AM
tooxtreme8813's Avatar
this is a good way to make your car even slower[:@]
Old Jun 3, 2008 | 03:24 AM
feerocknok's Avatar
But it sounds cool!
Get a piece of 5/8" heater hose, and cut a slit down the length of it, then slide it over the heat shield. It'll make the shield appear to be factory, since all the rest of the underhood sharp edges are covered. Maybe someday I'll take picsof my shield, but probably not.
Old Jun 3, 2008 | 04:43 AM
Leifer's Avatar
ORIGINAL: Tweaked
Speaking of hot air, you should ditch that stock SMIC and get a real intercooler
As for the "hot air" being sucked in; will the stock vs aftermarket really make a difference? The temperature variation between the outside air and the air under your hood may be large, but it really won't matter. By the time the air is utilized, the temperatures of a stock vs aftermarket intake will be very close, if not identical; to the point where such a trivial difference is insignificant.
All of this fuss over stock intake systems being better due to cool air is just mental masturbation.
Old Jun 3, 2008 | 04:49 AM
feerocknok's Avatar
Eh, I have a massive hole in my fender with mesh over it. The air is cold enough.
Old Jun 3, 2008 | 09:59 AM
BLK_A4's Avatar
its really not sucking any hot air at all. i know that intakes dont do that much for these cars. I am not stupid. i had even placed a small thermomater by the fillter so see if it is getting hot and its not so ya.
Old Jun 3, 2008 | 10:55 AM
euro_2nr's Avatar
I have the same **** in my car. Sounds way louder than my friend's 6 speed B6 and I don't even have a DV yet. Actually made my stock exhaust louder. I ghetto rigged a pretty good set up of heat shields and my filter stay cool to the touch. Evoms and Carbonio are no better than custom breathers and filters. Just pretty CF covers.
Old Jun 3, 2008 | 10:58 AM
Mike-2ptzero's Avatar
ORIGINAL: tooxtreme8813
Only in traffic and who needs to be faster while driving 10 mph.[8D]
Did younotice he is still using the stock inlet tube that feeds air to the stock air box? So he still has something directing outside air in that areawhich means the air temps will not be any higher then it woud be in the stock air box since the air is also being sucked out from that area from under the car as it is being driven hard.
Old Jun 3, 2008 | 11:06 AM
EliteTuning1's Avatar
i agree that it may be sucking in a bit of hot air, but at the same time not enough to actually make it slower in normal driving, i have the same style setup on my car so..........
