Cylinder 2 misfire CEL Any Ideas?
Old Apr 21, 2008 | 09:46 AM
dhypnotized's Avatar
Default RE: Cylinder 2 misfire CEL Any Ideas?
Ok just to re-cap
Parts I have Replaced.
*Mass Air Sensor
*Spark Plugs
*Spark Plug Wires
*Ignition Control Module
*Coil Pack
*Fuel Filter
*Cleaned Fuel Injectors
Any Suggestions would be appreciated......
Old May 2, 2008 | 05:26 PM
"UPDATE"
Took my car to Import Autoworks
They tested all the sensors "no errors"
Mechanic says it measured 12 inches of vacuum which should be more like 20?
So it seems I have a vacumm leak but even the mechanic has not been able to locate where its coming from.
Is there a place to look for these leaks that are hidden or uncommon?
Wondering if i have an intake gasket leaking......
Does anyone have a Diagram Of the Vacuum lines on this car??????????
Old May 2, 2008 | 05:31 PM
chaos92287's Avatar
do you have a 12v or 30v?
Old May 2, 2008 | 05:55 PM
Crunk's Avatar
Did you just change the coil pack on Cylinder 2? or all of them?
You maybe getting Random misfiring onthe othercylinders.
I would have changed out all 4, because if one is bad, you can bet ur A$$ the others will soon follow.
Otherwise, I would say Vaccuum hose or Wiring.
Old May 2, 2008 | 06:40 PM
K1196A's Avatar
you need to find a shop with asniffer for the engine. likely it's on the inside of an elbow or right along a hose clamp.
Old May 3, 2008 | 10:41 AM
chaos92287
Its the 12V
Old May 3, 2008 | 11:12 AM
chaos92287's Avatar
http://www.12v.org/maintenance/index...=tr&ss=vac
Russ Heinrichs
Aug 18, 2021 12:39 PM
ThePizza
Jul 23, 2008 05:16 PM
ChadS89
Jul 21, 2008 09:52 PM
A4 the Quattro
Apr 27, 2006 09:01 PM
