Cylinder 4 Misfire
Old Dec 20, 2008 | 01:21 PM
ST1FFY's Avatar
Member
Default Cylinder 4 Misfire
My cars check engine light came on about a week ago... I went to autozone today and had them scan it, the scan came up too show that cylinder 4 has a misfire malfunction, what could be causing this? all my mods and specs are in my sig
Old Dec 21, 2008 | 10:34 AM
ST1FFY's Avatar
Member
Could a bad MAF be a cause of this
Old Dec 21, 2008 | 12:14 PM
Tifun's Avatar
Or a bad coil pack. Swap the #4 coilpack with #1 and see if it moves the misfire.
Old Dec 22, 2008 | 07:13 PM
Armenian's Avatar
I actually had that happen couple of months ago, i just put in new spark plugs and reset the code , i think i had a bad spark plug, hope this helps,
Old Dec 22, 2008 | 09:01 PM
shayrgob's Avatar
check resistance of coil pack #4 and compare to spec or simply switch it w/ another cylinder's coil pack as mentioned. good luck
Russ Heinrichs
Aug 18, 2021 12:39 PM
and b
Feb 10, 2014 11:52 AM
ThePizza
Jul 23, 2008 05:16 PM
ricky0323
Feb 29, 2008 01:35 PM
