Dashboard won't light up help?
Old Sep 18, 2010 | 12:47 PM
peterbr1723's Avatar
Default Dashboard won't light up help?
I have an audi a4 and my dashboard won't light up any suggestions?
Old Sep 18, 2010 | 12:50 PM
I had just fix the headlights switch because they wouldn't light up I would only get high beams but as soon as I put everything how it was I got my lights working but my dashboard won't light up now
Old Sep 18, 2010 | 05:45 PM
BrianJanice's Avatar
It's a 3 amp fuse - same one as the headlight washers (they probably don't work either). Replace the fuse and it will work again.
Old Sep 19, 2010 | 11:45 AM
Dozanti's Avatar
mine goes in and out (bright to dim) when i hit bumps. I started messing with the illumination brightness **** and it seems the problem is there. mess with it and see if it changes anything. Also check the fuse as brianjanice suggested
Old Sep 19, 2010 | 12:34 PM
KinkySlayer's Avatar
illumination brightness ****?
Old Sep 19, 2010 | 01:03 PM
MiamiA4guy's Avatar
It might just be moving Scotch tape that bitch
Old Sep 20, 2010 | 06:18 AM
Where is that 3 amp fuse located at? So I can replace it
Old Sep 20, 2010 | 06:24 AM
Your right my headlight washers are also out.
Old Sep 20, 2010 | 08:58 AM
Um I think it's fuse #5... pry off the end of your dash on the driver's side of the car (there's a little slot you can fit a screwdriver in). The fuses start at the top left - count from top to bottom to the 5th fuse... it should be a 3A fuse that is blown. Replace it. Otherwise, look for other blown 3A fuses in there - I can check what the fuse number is later if you can't find the broken one.
Old Sep 21, 2010 | 07:23 AM
I can't see to find a 3a fuse the lowest number first I found was 5a I was looking at fuse box next to the drivers side correct?
