did i do my intake and dv right?
so i put in my new intake the other day and it went smoothly, minus me accidentally putting the maf back in the wrong way round. I freaked when the car at idle was bouncing between 840 rpm and 1000 rmp. but anyway with that fixed, it runs smooth again. I have a forge 007 dv in with the unpainted spring inside it. i can finally hear it now! But that is where my question comes in. When the dv releases air it makes a pfff noise. but when I am driving, it sounds like there is a long pfffffffff noise untill i let off the throttle and hear the pff noise of the release of the dv. I am not sure if this noise is a bad cat, my turbo, or the dv. it is a 98 1.8tm. i can probably get a sound clip for you guys and some pictures if it would help.
Thanks in advance,
miles
Thanks in advance,
miles
, i tightened it but I am hearing the same noise still. would it harm my engine if I tried a harder spring?
A boost gauge would be the best. If you are tight for funds, you can listen for turbo flutter. If its fluttering then its too tight, or when your wot and you can hear air escape then its to soft. You can either put in a new spring to tighten it up or if you only have one spring then you can go to ace or any other hardware store and put some washers in to stiffen in up. Long as its not fluttering then you wont be hurting the turbo though
the fluttering is not what hurts the turbo the most, the dv not opening correctly is what really hurts it, so just make sure its not too heavy or soft. This is why I love my forge splitter, it has an adjustment ring, which lets you dial in the perfect spring tension.
