Diiferential & Trans fluid ?
Old Dec 26, 2011 | 12:28 PM
rchachi's Avatar
Default Diiferential & Trans fluid ?
JUst got a 01 a4c1.8t manual transmission. 188,000 miles.
I want to change all of the fluids. I can't seem to find a yes or no answer. I am going to change the rear differential and transmission fluid (maybe). Is there a center or front diffwerential that I should change or is this part of the transmission fluid?
Is motul Gear fluid ok for the trannsmision? It says gl4 & gl5. It was changed with this. I was going to change it again with Redline MTL if its not the best.
Old Dec 26, 2011 | 12:51 PM
jonbonesjones's Avatar
Moderator
tranny and rear diff will cover everything you need. Gl4 and 5 can be used in both mogul 300 is fine.
Old Dec 26, 2011 | 01:15 PM
MetalMan's Avatar
There was just a thread about this a couple days ago:
https://www.audiforums.com/forum/b5-...ar-oil-177385/
yellow_submarine
Feb 3, 2011 04:25 AM
Juganotz
Nov 13, 2010 12:01 AM
jseel
Oct 19, 2010 11:06 PM
BRET OSSKO
Jul 11, 2010 09:58 PM
germancarmaniac
Aug 13, 2005 12:31 AM
