Dip in RPMs???
Old Sep 12, 2011 | 02:44 PM
murdox's Avatar
Default Dip in RPMs???
I am unsure if this happens to anyone else.. but..
car is idling, windows are up. I noticed if i hit the button for the windows to go up the rpms dip and you can feel the engine want to cut it. It's only for a second...
Is this a bad sign for my battery? Or is this simply how it works..
It also does it if i cut the wheel all the way left/right...
Old Sep 12, 2011 | 04:59 PM
airguard350's Avatar
Tech Guru
A blip in RPMs would be ok but the fact that it almost dies is bad. Do you have an OBDII or VAGCOM tool you could use? Is it showing a check engine light?
Old Sep 12, 2011 | 05:59 PM
MetalMan's Avatar
How low does the engine speed dip when this occurs? Mine might dip up to 100 RPM at times.
Old Sep 12, 2011 | 06:40 PM
murdox's Avatar
i personally do not have a vag com cable, but i have access to one, so i think ill tap into that this weeknd. No CELs though. the dip is only maybe a second, engine doesn't die either. Just a drop of 250-350 RPMs. Should i just use lemmiwinks or something to increase the idle speed? It idles around 900 rpms
Thanks for input guys.
Old Sep 12, 2011 | 07:39 PM
MetalMan's Avatar
Another quick question: if you rev the engine and release the throttle abruptly, how low does the RPM drop before it comes back to idle?
Old Sep 12, 2011 | 08:03 PM
murdox's Avatar
It doesn't drop lower then 800 or so when i rev it. It doesn't seem to dip when i rev it at all. I've only noticed the dip in rpms when i use the windows or sunroof. If its night time, i can even see the headlights dim down a bit when the rpms drop.
Old Sep 12, 2011 | 11:48 PM
TaConklin's Avatar
The window thing is odd, the steering wheel thing is normal. It even says so in your owners manual. Page 190-something I think, it says to not turn the steering wheel all the way to one side or the other and apply pressure, and if you do the RPM's will drop.
Old Sep 13, 2011 | 12:49 AM
MetalMan's Avatar
I would guess battery. See if you can get it tested at an auto parts store.
bbeach
Feb 21, 2012 06:25 PM
powersmokin
Jun 21, 2008 06:53 PM
nexusgroove
May 8, 2006 01:49 PM
yongk1
Nov 18, 2005 08:34 PM
Dudek12
May 4, 2005 10:31 PM
