Diverter Backwards?
Old Feb 28, 2008 | 05:21 PM
oettinger1919's Avatar
SoCal Crew Member
Default Diverter Backwards?
can someone simply explain which hose needs to go on which end of a DV. I think i have them backwards but the valve still works... Does the coolant return line go on the bottom port of the valve or is it the other way around. There are just no simple explainations or pictures i can find on the matter.
Old Feb 28, 2008 | 06:08 PM
chaos92287's Avatar
Default RE: Diverter Backwards?
the DIY article i made for the 006/004 explains it. piston valves should have the bottom of the valve in the turbo outlet hose and the side going to the TIP, diaphragm valves have the side going into the outlet hose and the bottom going to the TIP. and bov's just go into the turbo outlet hose
Old Feb 28, 2008 | 07:23 PM
SoCal Crew Member
TIP?
Old Feb 28, 2008 | 07:42 PM
Lazer Viking's Avatar
turbo. inlet. pipe
Old Feb 28, 2008 | 07:52 PM
chaos92287's Avatar
^yeah. its the pipe in between your intake and turbo.
https://www.audiforums.com/m_732016/tm.htm
theroadhawg
Apr 28, 2014 04:46 PM
Elpeejo
Nov 14, 2011 05:11 PM
Audi42005
May 10, 2006 08:19 PM
blades
Oct 19, 2004 10:18 PM
