AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   Diverter Valve Location Help (https://www.audiforums.com/forum/b5-models-69/diverter-valve-location-help-174430/)
01quattro Sep 26, 2011 08:20 PM
So my 710N DV is coming in the mail tomorrow. Did some searching but i havent found a straight answer or image to where the DV is located for my specific yr/engine code.
I have a 2001 A4 1.8T Quattro, AWM engine code, could someone tell me exactly where mine is located and/or provide an image or thread.
Thanks
CCA4 Sep 27, 2011 06:31 AM
Easiest way for you to get to it is from underneath. Jack the car up if you need to, take the belly pan off, and on the passenger's side of the engine find the turbo. There's a large rubber hose coming off the compressor housing that goes down to the intercooler hard pipe that runs the width of the car over to the intercooler. This rubber pipe is where the DV will be. Check this link out, its from the FAQ above:
https://www.audiforums.com/forum/b5-...mation-100217/
